The Complete Guide to ICU Message Format
•Last updated: •21 min read
ICU Message Format — The Complete Developer Guide
String concatenation is the original localization sin. It works perfectly in English, fails quietly in German, and breaks outright in Arabic. The moment you write "You have " + count + " messages", you have guaranteed that your app will produce grammatically wrong output for most of the world’s top twenty languages — without a single error being thrown.
ICU Message Format is the standard the industry converged on to solve this. It is the syntax behind react-intl, vue-i18n, Symfony’s Translator, Android’s quantity strings, and iOS’s stringsdict plural rules. If you do i18n (internationalization) at any scale, you are already working within the ICU ecosystem — or you should be.
This guide covers the full picture: the core icu syntax, every argument type with production-grade code examples, advanced nesting patterns that neither Phrase nor Lokalise’s guides document, framework implementations for React, Vue, Angular, and PHP/Symfony, and how to automate the entire icu translation workflow with Crowdin.
Free E-book on Continuous Localization!
Learn how to set up a continuous localization workflow to grow with multiple languages faster than with one. Experience and tips from 10+ localization experts.
Download
What is ICU message format?
ICU stands for International Components for Unicode. As the official ICU documentation defines it, ICU is a mature, portable set of C/C++ and Java libraries — known respectively as ICU4C and ICU4J — that provide Unicode and Globalization support for software applications. It is released under a nonrestrictive open-source license compatible with both commercial and free software.
The icu messageformat spec is one module within the broader ICU library suite. Its job is to express language-specific formatting rules — plurals, genders, ordinals, number notation, dates — in a single translatable string, driven entirely by runtime data.
The alternative is conditional code: if count == 1 then X else Y. That works for English. It does not work for Russian (which has four plural forms), Ukrainian (also four), or Arabic (which has six). Hard-coding branches makes localization a programming problem instead of a translation problem, and it cannot scale.
ICU solves this with a declarative syntax that puts the branching logic inside the string itself, where translators — not developers — can adapt it per language.
ICU i18n syntax — quick reference
Argument TypeSyntaxCommon Use Case
Variable{name}Dynamic name, count, value
Plural{count, plural, one {# item} other {# items}}Counts with CLDR plural rules
Select{gender, select, female {She} male {He} other {They}}Gender, role, status
SelectOrdinal{rank, selectordinal, one {#st} two {#nd} few {#rd} other {#th}}Rankings, positions
Number{price, number, ::currency/USD .00}Currency, percent, compact
Date{date, date, long}Locale-aware date display
Time{time, time, short}Locale-aware time display
Core ICU syntax
Simple interpolation
The most basic icu format argument is a named placeholder wrapped in single curly braces.
First, define your key in the translation file:
"welcome_user": "Welcome back, {name}!"
Then, pass the value through your translation function to render the final string:
intl.formatMessage({ id: "welcome_user" }, { name: "Alice" });
// → "Welcome back, Alice!"
One critical detail: ICU uses single curly braces. Double curly braces ({{name}}) are not valid ICU syntax — they will cause a parser error in libraries like react-intl and Symfony’s Translator. This is the first mistake most developers make when migrating from a Mustache-style format.
Plural
The icu formatting plural argument maps a numeric value to a CLDR plural category and selects the correct message form:
{counterVariable, plural, ...pluralForms}
CLDR plural categories:
CategoryTypical use
zeroExplicit zero (not all languages distinguish this)
oneSingular (English: 1)
twoDual (Arabic, Hebrew)
fewPaucal (Slavic languages, Arabic)
manyUsed in Polish, Russian, Arabic for larger counts
otherRequired. Universal fallback for any unmatched value.
The other category is always required by the ICU standard, regardless of the target language.
"unread_messages": "{count, plural,\n =0 {No unread messages}\n one {# unread message}\n other {# unread messages}\n }"
The # token is replaced by the numeric value of the count variable. The =0 exact-match override fires before CLDR rules are evaluated — use this for zero-state copy that differs structurally from the regular plural (e.g., “No messages” vs. “1 message”).
ICU plural in Crowdin
The offset: modifier
One of the least-documented and most useful features of ICU plural is the offset: modifier. It subtracts a fixed number from the count before applying CLDR rules, which allows you to express patterns like “You and N others liked this” without any application-level arithmetic.
Define your plural logic in the translation file. Breaking it into multiple lines makes the offset and its conditions much clearer:
"post_likes": "{likeCount, plural, offset:1\n =0 {No one has liked this yet}\n =1 {You liked this}\n one {You and one other person liked this}\n other {You and # other people liked this}\n }"
When you pass likeCount, the ICU formatter applies the offset and selects the appropriate string:
// likeCount = 0 → "No one has liked this yet"
// likeCount = 1 → "You liked this"
// likeCount = 2 → "You and one other person liked this"
// likeCount = 25 → "You and 24 other people liked this"
With offset:1, the value passed to CLDR plural rules is likeCount - 1, and the # token also renders the offset-adjusted value. The =0 and =1 exact-match overrides fire before the offset is applied, so they match the raw likeCount.
Select — conditional branching on strings
The select argument works like a switch statement over a string variable. It is most commonly used for gender-based pronoun selection, but it applies to any discrete string condition — user role, subscription tier, account type, device type:
"pronoun_possessive": "{gender, select,\n female {her}\n male {his}\n other {their}\n }"
Every select expression must include an other branch. This is the ICU standard’s required fallback — if the runtime variable does not match any explicitly listed branch, other fires. Omitting it is a syntax error in strict parsers.
ICU select in Crowdin
SelectOrdinal — rankings and positions
Cardinal plurals answer “how many?” Ordinal plurals answer “which position?” The selectordinal argument maps to CLDR ordinal rules.
Define your ranking logic in the JSON file. You can use line breaks within the string to keep it readable in your editor:
"leaderboard_position": "You finished in {rank, selectordinal,\n one {#st}\n two {#nd}\n few {#rd}\n other {#th}\n } place!"
When you pass the rank value, the ICU formatter automatically picks the correct suffix based on the locale’s rules:
// rank = 1 → "You finished in 1st place!"
// rank = 2 → "You finished in 2nd place!"
// rank = 3 → "You finished in 3rd place!"
// rank = 11 → "You finished in 11th place!" (English 'other', not 'one')
English has four ordinal forms: one (1st, 21st, 31st), two (2nd, 22nd), few (3rd, 23rd), and other (everything else). This differs per language — CLDR defines the ordinal rules for each locale.
Number formatting with ICU skeletons
ICU’s number formatting moved from named styles (integer, currency, percent) to a more expressive number skeleton system. Skeletons use a :: prefix and compose multiple formatting tokens.
Define your complex number formatting in the translation file:
"billing_summary": "Your plan is {price, number, ::currency/USD .00}/mo. You save {savings, number, ::currency/USD .00} ({discount, number, ::percent .#}) vs monthly. {seats, number, ::compact-short} seats included."
Then, pass your numeric values. Notice how the code is structured to keep lines short and readable:
intl.formatMessage(
{ id: "billing_summary" },
price: 79,
savings: 158,
discount: 0.166,
seats: 12400
// en-US → "Your plan is $79.00/mo. You save $158.00 (16.6%) vs monthly. 12.4K seats included."
// de-DE → "Ihr Plan kostet 79,00 $/ Monat. Sie sparen 158,00 $ (16,6 %) vs. monatlich. 12.400 Plätze inklusive."
Key skeleton tokens:
SkeletonMeaningExample output (en-US)
::currency/USDCurrency, locale symbol$79.00
::currency/USD .00Currency, always 2 decimal places$79.00
::percentPercentage17%
::percent .#Percentage, 1 optional decimal16.6%
::compact-shortCompact notation12.4K
::compact-longLong compact notation12.4 thousand
::integerInteger, no decimals42
Skeletons are the modern replacement for named styles. New code should always use the :: skeleton syntax. The named style forms ({n, number, currency} without ::) were deprecated in ICU 72.
Date and Time formatting
ICU date and time arguments use four predefined styles — short, medium, long, full — and render according to the active locale’s conventions automatically.
First, define your translation key with the date and time placeholders:
"meeting_reminder": "Your meeting is on {meetingDate, date, long} at {meetingTime, time, short}."
Then, pass standard JavaScript Date objects as values. The library will handle the localization for you:
intl.formatMessage(
{ id: "meeting_reminder" },
meetingDate: new Date("2026-03-15"),
meetingTime: new Date("2026-03-15T14:30:00")
// en-US → "Your meeting is on March 15, 2026 at 2:30 PM."
// de-DE → "Ihr Meeting ist am 15. März 2026 um 14:30."
// ar-SA → "اجتماعك في ١٥ مارس ٢٠٢٦ في ٢:٣٠ م."
ICU date in Crowdin
Styleen-US output
short3/15/26, 2:30 PM
mediumMar 15, 2026, 2:30 PM
longMarch 15, 2026 at 2:30 PM
fullSaturday, March 15, 2026 at 2:30 PM
Advanced ICU formatting: nesting arguments
This is where icu i18n separates from every simpler approach. A single translatable string can encode dozens of grammatically correct output variants by nesting argument types inside each other.
Nested plural inside select
Scenario: An activity feed in a SaaS application. The message must reflect the actor’s gender (which affects pronouns in many languages) and the number of files they shared (which requires plural handling). Both variables affect the sentence structure simultaneously.
Concatenating these as separate strings (actor + " shared " + count + " files") is incorrect for any language that inflects based on quantity or gender. The correct approach is a single ICU string with select wrapping plural:
{actor} {gender, select,
female {
{fileCount, plural,
=0 {did not share any files — check her profile}
one {shared {fileCount, number, ::integer} file — view her upload}
other {shared {fileCount, number, ::integer} files — see her uploads}
male {
{fileCount, plural,
=0 {did not share any files — check his profile}
one {shared {fileCount, number, ::integer} file — view his upload}
other {shared {fileCount, number, ::integer} files — see his uploads}
other {
{fileCount, plural,
=0 {did not share any files — check their profile}
one {shared {fileCount, number, ::integer} file — view their upload}
other {shared {fileCount, number, ::integer} files — see their uploads}
Evaluation order: The ICU parser evaluates the outermost argument first (gender → select), then the inner argument (fileCount → plural), then the innermost inline format (fileCount → number skeleton).
Rendered output:
actorgenderfileCountOutput
Alicefemale0Alice did not share any files — check her profile
Alicefemale1Alice shared 1 file — view her upload
Alicefemale42Alice shared 42 files — see her uploads
Bobmale3Bob shared 3 files — see his uploads
Alexother1Alex shared 1 file — view their upload
This single string replaces 9 conditional branches in application code, and gives translators full control over adapting the grammatical structure per language.
Escape sequences
Single quotes in ICU have special meaning: they start a quoted literal, which disables ICU argument parsing for the quoted région. This is the most common silent bug in ICU translation files, because it produces no runtime error — it simply renders the wrong text.
The rules:
SequenceRenders as
''A single apostrophe '
'{'A literal { (not an argument)
'}'A literal } (not an argument)
'text'The literal string text
"apostrophe_broken": "It's {count, plural, one {# file} other {# files}}.",
"apostrophe_correct": "It''s {count, plural, one {# file} other {# files}}.",
"literal_braces": "Use '{'variable'}' to interpolate values."
In apostrophe_broken, the single quote before s starts a quoted literal region. The ICU parser exits argument-parsing mode and treats {count, plural, one {# file} other {# files}} as plain text. The output is the raw string — count, plural, one {# file} other {# files} — instead of the rendered plural.
In apostrophe_correct, '' produces one literal apostrophe and the parser remains in normal mode, so {count, plural, ...} is processed correctly.
This bug is most common when translators copy-paste strings containing natural-language apostrophes. Crowdin’s built-in ICU Syntax Error detection in the Editor catches this class of error automatically and surfaces a fix suggestion before the string is ever downloaded.
Multi-language plural files in practice
The same translation key requires a different number of plural form branches in every language. You cannot hard-code one and other and call it done — that assumption is only valid for Germanic languages.
English (translations/messages.en.json) — 2 plural forms:
"subscription_days_remaining": "Your subscription expires in {days, plural,
one {# day}
other {# days}
German (translations/messages.de.json) — 2 plural forms (same CLDR structure as English):
"subscription_days_remaining": "Ihr Abonnement läuft in {days, plural,
one {# Tag}
other {# Tagen}
} ab."
German rules: one when n = 1 exactly. other for everything else (0, 2, 3 … ∞, and all decimals). German and English share the same two-form CLDR plural structure — but the noun itself inflects (Tag → Tagen), so the ICU plural is still required even though there are only two branches.
Arabic (translations/messages.ar.json) — 6 plural forms (CLDR):
"subscription_days_remaining": "تنتهي صلاحية اشتراكك خلال {days, plural,
=0 {لا أيام متبقية}
one {يوم واحد}
two {يومين}
few {# أيام}
many {# يوماً}
other {# يوم}
Output at days = 21:
LocaleOutputPlural form applied
enYour subscription expires in 21 days.other
deIhr Abonnement läuft in 21 Tagen ab.other
arتنتهي صلاحية اشتراكك خلال ٢١ يوماً.many (11–99 range)
English and German resolve identically at 21 — both use other. Arabic resolves to many. This is why ICU plural is mandatory even between closely related languages: German requires the dative plural form Tagen where English uses the same days regardless of count.
Common ICU mistakes — quick reference
MistakeWrongCorrect
Apostrophe in textIt's {n, plural, ...}It''s {n, plural, ...}
Double curly brace{{name}}{name}
Missing other clause{g, select, male {...}}Always include other {...}
String concatenation"You have " + n + " files"{n, plural, one {# file} other {# files}}
Wrong offset: position{n, plural, =0 {...} offset:1}{n, plural, offset:1 =0 {...} ...} — offset must come first
Deprecated number style{n, number, currency}{n, number, ::currency/USD} — use skeletons
I18n libraries that support ICU message format
While ICU provides the foundational capabilities, many i18n libraries across programming languages and platforms have implemented icu messageformat support. The most widely used are listed below. Note that some libraries implement different subsets of the ICU spec — read their documentation to confirm which argument types and features are available before committing to one.
C/C++
  • ICU4C — The reference implementation of ICU in C and C++. Full spec compliance.
Dart / Flutter
  • intl — The first-party Dart i18n package. Implements ICU message formatting including plural and select.
  • flutter_i18n — Flutter’s localization layer, also ICU-based.
Java
  • ICU4J — The reference Java implementation. Full spec compliance, including number skeletons and all CLDR plural rules.
JavaScript
JavaScript localization does not have an official first-party ICU implementation in the language spec, so developers choose from well-established third-party libraries:
  • react-intl / @formatjs/intl — The most widely used ICU implementation in the JavaScript ecosystem. Supports all argument types including number skeletons and nested expressions. Powers the React examples in this guide.
  • vue-i18n v10 — Vue 3’s primary i18n library. Requires the @intlify/unplugin-vue-i18n Vite plugin with icu: true to enable ICU parsing at build time.
  • messageformat — Built directly around the ICU MessageFormat standard. Supports all Unicode CLDR languages.
  • i18next with ICU module — The official ICU extension for i18next, which itself powers many React, Next.js, and vanilla JS applications.
PHP
  • Symfony Translation Component — Symfony’s translator with full ICU message format support via the PHP ext-intl extension. Requires ICU ≥ 72 for complete CLDR plural rule coverage. The implementation examples in this guide use Symfony 7.x.
Python
  • PyICU — Python wrappers for the ICU C++ libraries. Provides full ICU formatting capabilities in Python code.
Framework implementations
React: react-intl v7
Step 1: Installation & setup
To get started, install the react-intl package via your terminal:
Terminal window
npm install react-intl
Once installed, wrap your root component with the IntlProvider. This setup ensures that all child components have access to your translation messages:
src/main.tsx
import { IntlProvider } from "react-intl";
import enMessages from "./translations/en.json";
<IntlProvider locale="en" defaultLocale="en" messages={enMessages}>
<App />
</IntlProvider>;
Step 2: Translating Content
React Intl provides flexible ways to handle translations. You can use the imperative API for attributes or the declarative API for standard UI elements:
// Imperative API (aria-labels, page titles)
const intl = useIntl();
const label = intl.formatMessage(
{ id: "activity_feed_item" },
{ actor: "Alice", gender: "female", fileCount: 3 }
// Declarative API (JSX)
<FormattedMessage id="activity_feed_item" values={{ actor, gender, fileCount }} />;
Summary: useIntl gives the imperative formatMessage API, which is required anywhere a string value is needed outside of JSX — ARIA attributes, <title> tags, toast notifications. <FormattedMessage> handles most JSX render cases.
Vue: vue-i18n v10 (Composition API)
First, install the core library and the necessary Vite plugin for ICU support:
Terminal window
npm install vue-i18n@10 @intlify/unplugin-vue-i18n
Step 2: Vite configuration
Configure your vite.config.ts to enable ICU message parsing at build time:
// vite.config.ts — enable ICU parsing at build time
import VueI18nPlugin from "@intlify/unplugin-vue-i18n/vite";
plugins: [
vue(),
VueI18nPlugin({ icu: true, include: resolve(__dirname, "./src/translations/**") })
Step 3: Usage in components
Now you can use the Composition API to handle translations and rich text formatting:
<script setup lang="ts">
import { useI18n } from "vue-i18n";
const { t } = useI18n();
const feedText = computed(() => t("activity_feed_item", { actor, gender, fileCount }));
</script>
<template>
<p>{{ feedText }}</p>
<!-- Rich text with embedded components -->
<i18n-t keypath="meeting_reminder" tag="p">
<template #meetingDate>
<time>{{ formattedDate }}</time>
</template>
</i18n-t>
</template>
The <i18n-t> component is vue-i18n’s mechanism for injecting Vue components into named argument slots in an ICU message — use this for cases where a date, link, or styled span must appear inline within a translated string.
Angular — @ngx-translate/core + intl-messageformat
Since Angular’s built-in @angular/localize does not support runtime locale switching from JSON files, start by installing the core library and intl-messageformat for ICU parsing:
Terminal window
npm install @ngx-translate/core @ngx-translate/http-loader intl-messageformat
Step 2: Create an ICU Translation Service
To integrate ICU formatting into your workflow, create a service that wraps intl-messageformat. This allows you to handle complex pluralization and gender rules dynamically:
icu-translate.service.ts
import IntlMessageFormat from "intl-messageformat";
import { TranslateService } from "@ngx-translate/core";
@Injectable({ providedIn: "root" })
export class IcuTranslateService {
private translate = inject(TranslateService);
async format(key: string, values: Record<string, unknown>): Promise<string> {
const raw = await firstValueFrom(this.translate.get(key));
const locale = this.translate.currentLang ?? "en";
try {
return new IntlMessageFormat(raw, locale).format(values) as string;
} catch {
return raw; // Graceful degradation — never throw to the UI
The try/catch block on the ICU formatter is not optional. A malformed ICU string from a translator will throw at runtime. Returning the raw message key as a fallback keeps the UI functional while the error is logged for fixing.
PHP — Symfony 7.x
Step 1: Controller Usage
In Symfony, the TranslatorInterface automatically handles ICU messages if your translation files (e.g., .en.icu.yaml) are named correctly. You can pass parameters directly in your controller:
src/Controller/FeedController.php
$message = $this->translator->trans(
parameters: [
'actor' => 'Alice',
'gender' => 'female',
'fileCount' => 3,
domain: 'messages',
locale: 'en',
// → "Alice shared 3 files — see her uploads"
Step 2: Twig Templates
In your templates, you can use either the trans filter for simple strings or the trans tag for longer blocks of content:
{# Twig filter syntax #}
{{ 'unread_messages'|trans({'count': unreadCount}) }}
{# Twig tag syntax — for longer strings #}
{% trans with {'actor': actor, 'gender': gender, 'fileCount': fileCount} %}
activity_feed_item
{% endtrans %}
Symfony reads translation files from the translations/ directory. The trans filter and tag both pass the parameter array directly to the ICU formatter via the PHP ext-intl extension. Run php -m | grep intl to confirm the extension is loaded.
Watch this 4-minute video to learn about Crowdin
Automate ICU translation with Crowdin
Writing ICU strings correctly is the developer’s responsibility. Keeping them translated, in sync, and free of syntax errors across dozens of languages is a different problem — and one that does not belong in your CI pipeline as a manual step.
Crowdin catches ICU syntax errors
Crowdin Editor: ICU-Aware Translator UX
The Crowdin translation Editor has first-class support for ICU syntax:
  • Argument highlighting: Every {argument} is rendered as a distinct, non-editable chip. Translators reposition chips to match the target language’s word order without ever touching raw syntax.
  • Automatic Syntax Error detection: The Editor detects unclosed braces, missing other clauses, broken apostrophe escapes (it's instead of it''s), and wrong =n specifiers in real time. Translators see an inline warning with a suggested fix before submitting the string. To enable this, go to your project → Home → QA → ICU Syntax.
  • Copy Source for plurals: Clicking Copy Source on a plural string automatically inserts the correct number of CLDR plural form fields for the target language. For an Arabic translator, Crowdin inserts all six form fields. For an English translator, two. This eliminates the most common plural localization error.
  • Preview mode: Powered by in-context localization, this lets translators see a rendered version of the string with sample values substituted — they verify output, not raw ICU syntax. This is critical for complex nested strings where the rendered output differs significantly from the source.
To work with ICU strings specifically, go to your project → open Editor → Advanced Filter → String Type → ICU.
Also refer to the ICU message syntax reference in Crowdin’s documentation for the full list of supported argument types.
Automating Sync with the Crowdin CLI
The Crowdin CLI provides push and pull commands for integrating translation file sync into any CI/CD pipeline.
Step 1: Project configuration
First, create a crowdin.yml file in your root directory. This file defines your project ID and maps the source files to their respective translation paths:
# crowdin.yml — project configuration
project_id: "YOUR_PROJECT_ID"
api_token_env: CROWDIN_PERSONAL_TOKEN
base_url: "https://api.crowdin.com"
base_path: "."
files:
- source: /translations/en.json
translation: /translations/%two_letters_code%.json
Step 2: GitHub Actions workflow
To fully automate the process, set up a GitHub Action. This workflow will automatically push new source strings and pull completed translations whenever you merge code into the main branch:
.github/workflows/crowdin.yml
on:
push:
branches: [main]
jobs:
sync:
runs-on: ubuntu-latest
steps:
- uses: actions/checkout@v4
- uses: crowdin/github-action@v2
with:
upload_sources: true
download_translations: true
env:
CROWDIN_PROJECT_ID: ${{ secrets.CROWDIN_PROJECT_ID }}
CROWDIN_PERSONAL_TOKEN: ${{ secrets.CROWDIN_PERSONAL_TOKEN }}
This workflow uploads new or changed source strings on every merge to main, and downloads completed translations back into the repository — closing the loop between development and localization without manual intervention.
n8n Crowdin nodes: no-code automation
For teams that manage localization triggers from external systems (CMS updates, content approval workflows, release pipelines), the Crowdin n8n nodes provide a no-code integration layer.
Common automation patterns with Crowdin’s n8n nodes:
  • Trigger a source file upload when a CMS article is published
  • Notify the localization team in Slack when a translation reaches 100%
  • Automatically download and deploy translations when all languages are approved
The n8n nodes support the full Crowdin API, which means any action available via the CLI is also automatable via n8n workflow triggers.
React Native SDK: Over-the-Air ICU updates
Mobile apps that use ICU-formatted strings face a specific delivery constraint: updated translation files typically require an App Store or Play Store release. The Crowdin React Native SDK solves this via over-the-air (OTA) distribution.
import { CrowdinOtaClient } from "@crowdin/crowdin-ota-client";
// Initialize with your Crowdin distribution hash
const client = new CrowdinOtaClient("YOUR_DISTRIBUTION_HASH");
// Fetch ICU strings for a specific locale at runtime
const translations = await client.getStringsByLocale("de");
With OTA delivery, a copywriter can fix a broken ICU apostrophe escape or a translator can correct a plural form in any language without the development team cutting a new release. The SDK fetches the latest approved translations from Crowdin’s CDN on app start.
Conclusion
ICU Message Format is the correct engineering approach to any application that will serve users in more than one language. String concatenation produces wrong output. Conditional branches do not scale. ICU puts the linguistic logic where it belongs: in the translation file, managed by translators, validated by tooling.
The patterns covered in this guide — icu formatting with number skeletons, offset: for social counters, nested select + plural for activity feeds, and proper apostrophe escaping — are the production-grade techniques that appear in real SaaS applications at scale. They are also the techniques that Phrase’s and Lokalise’s guides omit.
For icu translation at scale, Crowdin’s Editor, CLI, n8n nodes, and React Native SDK form a complete pipeline: translators work in an ICU-aware environment that prevents syntax errors, source strings sync automatically via CI, and mobile updates ship without an app store release.
What is the difference between ICU Message Format and printf-style formatting?
printf supports positional interpolation only (%s, %d). ICU adds named variables, CLDR plural rules, select branching, and locale-aware number and date formatting in a single string — without any application-level conditional logic. The two are not interchangeable; ICU is a superset designed specifically for localization.
Do I need ICU for an English-only application?
Not strictly. For single-language apps, ICU adds a dependency without contributing visible value. However, adopting ICU syntax from the start means adding a second language requires only a new translation file, not refactored application code. The cost of retrofitting ICU into a mature codebase is significantly higher than adopting it early.
Will ICU strings work in my existing JSON localization files?
Yes. ICU values are plain strings — they are fully compatible with standard JSON and YAML. The ICU parser is in the i18n library (react-intl, vue-i18n, Symfony), not the file format. Existing files require no structural changes; only the string values change.
How do I validate ICU syntax before shipping?
For local development: use the Online ICU Message Editor for quick interactive checks, or add @formatjs/eslint-plugin-formatjs to your linter for CI enforcement. In Crowdin, the Editor performs automatic syntax validation on every string a translator submits.
What is the offset: modifier in ICU plural, and when should I use it?
offset:N subtracts N from the count before ICU applies CLDR plural rules, and also adjusts the # token output by the same amount. Use it when your message combines a fixed actor (e.g., “You”) with a variable number of additional actors (e.g., “and N others”). Without offset:, you would need application-level arithmetic before passing the count to the formatter.
